Disable RMON1 History
Disable RMON1 history on a port if you do not want to record a statistical sample from that port.
  1. In the navigation pane, expand Configuration > Serviceability > RMON.
  2. Select Control.
  3. In History, select the row that contains the port ID to delete.
  4. Select Delete.
